Advanced Dashboards and Visualizations with Splunk 8.1
Upcoming Classes
Online
Instructor-led online training
Location | Feb 2023 | Mar 2023 | Apr 2023 | May 2023 | Jun 2023 | Jul 2023 | Aug 2023 |
AMER Eastern Time - Virtual |
Feb 3 |
Mar 3 Mar 31 |
Apr 28 | ||||
EMEA UK Time - Virtual |
Feb 17 |
Mar 14 |
Apr 14 | ||||
AMER Pacific Time - Virtual |
Feb 21 |
Apr 14 | |||||
APAC Singapore - Virtual |
Mar 10 |
Summary
This one-day course is designed for advanced users who want
to create SplunkJS dashboards and Splunk Custom Visualizations. It focuses on creating dashboards, adding inputs, using event handlers and creating Splunk Custom Visualizations using JavaScript and XML.
Objectives
Module 1 – SplunkJS Dashboards
- Identify view types
- Create a SplunkJS dashboard
- Define view properties, methods and events
- List types of search managers
Module 2 – Using Tokens
- Use tokens in SplunkJS
- Define Splunk’s token models
- Describe how to get, set, and change tokens
- Create a SplunkJS form
Module 3 – Using Event Handlers
- Identify types of event handlers
- Define event handler syntax
- Define drilldown properties
- Create an event handler
Module 4 – Creating Custom Visualizations
- Define the custom visualization primary files
- Add custom visualizations to views
- Create a custom visualization
- Define security best practices
To be successful, students should have a solid understanding of the following courses:
- Splunk Fundamentals 1
- Splunk Fundamentals 2
- What Is Splunk?
- Intro to Splunk
- Using Fields
- Visualizations
- Data Models
- Introduction to Dashboards
- Dynamic Dashboards
- Using a terminal editor (vi,nano, etc)
- Editing JavaScript, XML, CSS and HTML
